Looked at the Eastern Beaver kit. I'm thinking the "H4 Dual Headlight Relay Kit with LO Beam On/Off Switching" is similar or maybe the same thing as I built. Looks like a nice kit. If I hadn't known how to piece together such a thing then I would have bought one from Eastern or whomever else is selling things.
If you like to tinker or simply find satisfaction from doing things yourself. Two critical parts are pictured below.
You'll need the two (2) relays and two (2) sockets. The pic below shows both the relay and socket mated together. An autoparts store sometimes sells them as separate pieces. You'll need a socket for each relay. You'll need two relays.
The headlight extensions are where you'll get the sockets and plugs for the head lamps.
Here is one way to wire up the two relays.
Background:
For the two relays, one relay controls the low beams of both head lamps. The other relay controls the high beam of both head lamps.
1. You'll run a line from the battery and attach it to the terminal marked #30 of BOTH relays.
2. The terminal #87a will be left unconnected on BOTH relays. Tape up the wire so the end of the wire doesn't short against anything.
3. Unplug both head lamps from the stock harness. Tape one of the plugs up so dust doesn't get into it. You'll use the other plug for control voltages. Cut the two head light extensions from fleabay in half. Plug one of the black plugs into the head light socket, which you just unplugged from the headlight.
4. Ground pin #86 of BOTH relays.
5. Connect the low beam from the stock harness to pin #85 of ONE relay.
6. Connect pin #87 of that relay to the low beam of both head lamps.
7. Connect the high beam from the stock harness to pin #85 of the OTHER relay.
8. Connect pin #87 of the OTHER relay to the high beam of both head lamps.
9. Connect the ground lead on BOTH head lamps to ground.
Theory of operation:
When the bike's ignition is OFF, there is no voltage present on pin #85 of either relay. Power isn't applied to the headlights when the ignition is off. It is how this bike is made.
Both relays are connecting battery voltage pin #30 to pin #87A. Pin 87A is left unconnected on BOTH relays. Current doesn't flow anywhere. Nothing bad here. When unpowered, the relay connects pin #30 to pin #87a. It is how this relay is made.
When the ignition is ON and low beam is selected, pin #85 has 12 Volts on it. Relay ONE connects battery voltage pin #30 to pin #87. Pin #87 is connected to the low beams of both head lamps, using the cut in half fleebay headlamp extensions. Both lamps illuminate.
When the ignition in ON and high beam is selected, pin #85 of the OTHER relay has 12 Volts on it. The OTHER relay connects battery Voltage pin #30 to pin #87. Pin #87 of the OTHER relay is connected to the high beam of BOTH head lamps, again using the other cut in half head lamp extension.
When the ignition is on and the yellow headlight flash button is pressed, BOTH relays have 12 on pin #85, which causes both relays to operate as described above.
If you want the ability to switch off one of the beams, either the high or low. put the switch between pin #85 of the relay controlling that beam and what pin #85 is connected to.
When you're done, you'll have one black plug from the headlamp extensions that you bought off of fleabay left over.
Aside, these "ice-cube" relays as lay people sometimes call them, are handy to have around. If you end up buying more than two, it might be an okay thing.
It will be helpful for you to draw of diagram of what is connected to what to double check everything goes to where it makes sense. I did this 5 years ago and am recalling what I did from memory.
Let me know if you have any questions.
Good luck.
