hey whats up,
2008 vstrom 1000 93000kms
No engine mods
Plugs and filter changed over the winter
One tooth less front sprocket
I was wondering if anyone else has experieneced this symptom.
When im cruising 4-5krpms in 4th or 5th the bike will feel like its losing speed then speeds up then loses speed again. Almost like im rolling on/off the throttle. My voltage meter doesnt change and my rpms and speed dont move.
I started wondering if it was wind buffeting or the roads, cause it happens intermittently.
Just wondering if anyone else has experienced this.
Thanks so much
May be time to order a TPS. They probably spend more time between 4000 and 5000 RPM than anywhere else, so adds are there is a worn spot on the TPS in that range.
I would agree with the TPS or fuel pump.
Only when hot ???
You could try a TPS reset.
With the ignition off fully open and close the throttle a few times.
If things improve it points to the TPS being bad.
The reset will not fix a bad TPS it just helps a bit sometimes.
The fuel pump sounds fine and i plan on doing a pump test in the off season, im gonna look at the tps and try the reset
Only when hot ???
Yes its only once its been warmed up and running hot
So i took the bike out this morn after the TPS reset and it was still doing it. I have a Heal Tech DS series gear thing that shows me what gear im in and i noticed that its showi g me in 5th when im in 4th and thats when it starts to pull and then let off while i hold the throttle. I didnt install this but was wondering if this is some how a problem?
So tell me if im crazy but i reset the
Gear selecter it came up C07 on the screen and then i just rode and now i dont get any weird lag between 4 and 5 k in forth gear. It doesent gear up to 5th on the screen when im revving it at 5k in 4th.
Could the problem be gone ?
