1 - 1 of 1 Posts
I have pared down my list of farkles on my 2014 650 to the last few: power outlets and a switch for aux. lites. Instead of an expensive fuse block, I got a $15 fuse block from Interstate Battery, a $25 waterproof USB port from burnsmoto.com and a $25 waterproof switch from West Marine. I installed all together running the wires behind the tank panels. The fuse block was set in a discarded prescription plastic case, and fit the application perfectly. My choice of USB port was based on my applications: Most are USB charged. I run my tire pump off the SAE battery connector.
burnsmoto.com has all the connectors you'll need, check them out.
1 - 1 of 1 Posts
