My radiator is running whenever the water pump is turning, which is, I hope, anytime the engine is running. If it were not, I'd be very concerned. :biggrinjester:What level does your radiator run at?
Good to know. My 03 has hit 4 bars a few times during low speed junk. I do notice the fan running when I shut off the motor but have the ignition on. So at least I know it is functional.Those early models (02/03) tend to read a little high,or at least display high. If you're getting a fan at stops, and slow traffic for a short time, then you're fine. If the fan is running non stop, you'll need to look into it farther.
I used to overheat quickly but I had that recall service done. Now I'm staying usually at 2 bars. I use the bike mostly with the wife or going out for at least a full day so I'm at highway speeds. I stay at two bars throughout most of the day and the fan doesn't come on.
