Hey guys thought id look in to this problem before I take it to the shop.
On a fairly rough off road ride my instuments all stoped working, thats speedo, tacho, fuel, temp and indicators now wont work eather however the clock still does. Has any one experienced this problem before :confused:
Thanks in advance,
Chef
Check the fuse box under the seat. The 15A signal fuse has probably blown. Mine has gone out on a few occasions this winter and I'm not sure why either, stator problem?
Also, check the wiring harness for shorts. The wires under the fuel tank can be rubbed through and short. This can cause everything in the gauge cluster to go dead. Ask me how I know. :headbang:
You probably don't have a tail light / brake light either.
I had a short on my first '04 DL650 in the main wiring harness that kept blowing that fuse and losing tail lights and all dash items.
Discussion Starter · #5 ·
The first thing I did was check the fuses, and they where all fine. Seems a bit werd that everthing is out but the clock :confused:
The clock requires very little power and is on whether the ignition is or not. A marginal connection in the ignition on power wire to the cluster will do just what you describe for example. If you get a tail and brake light, check the large connector under the rubber cover in the left side of the fairing and the connection to the instrument cluster itself.
Discussion Starter · #7 ·
Thanks I will try all the conectors before I send to the shop. If I cant find anything do you think it would be covered under waranty ?
If your warranty has not expired, it should be.
