1 - 11 of 11 Posts
Is there any mods that need to be done prior to installing? I am trying but running into problems with the throttle cables and the brake lever rubbing.:headbang:
Any help would be greatly appreciated.
Thanks,
Doug
Discussion Starter #2
Some differences
Thanks for the pics. I see some differences, not sure how much the affect things.
You have a 1000, and looks like you extended your throttle cables, and your brackets are different than mine. The shell is the same.
I will try to use the pics and see if that helps.
Thanks again!:thumbup:
I have the Acerbis Multi Concept on my 650 with the acerbis brackets. I had to move a few things around a bit, but did not cut or alter anything. I can send pics if youd like.
Sent you a PM
You have pm.
Hiya guys,
I'm new here and so is my DL1000 experiance. The previous owner had protaper bars (seven/eights) fitted along with Acerbis Multyconcept hand guards. It looks like in case of a fall the Acerbis mounts mounts could rotate taking out the Clutch/Break lines. This can also bee seen on th epic above.
Is there any experiance on that or am I just imagining BS.
thanks & Cheers
Is there any mods that need to be done prior to installing? I am trying but running into problems with the throttle cables and the brake lever rubbing.:headbang:/QUOTE]
You might have to rotate/move cables and controls a bit to make everything fit.
Same problem here
I also have Acerbis Multiconcept, I mounted them about a year ago moving controls and forcing a little bit the mounting brackets. After a tipover aluminium bent a little and now it rubs more brake line. Can you post pics about your assembly solutions so that I can get an idea on how can I solve this?
Gus-Strom
One More
They would only let me put five.
Thanks Switchfoot for the reply and sorry taking so long to answer.
I kind of solved the problem with a special made adapter, it makes the handguard a little bit forward. I´ll post some pics as soon as possible.
Regards
1 - 11 of 11 Posts
