Installed the givi skid plate lastnight. Straight forward install not too bad. It is a light weight plate not for heavy off road riding. But I'm happy with it so far. Bought it from a forum member.
The bottom 4 screws need to come out. With that said, the four rubber washers that fit between the bottom brackets and the top side of the skid plate are a big PITA when putting back together. Also, be careful because some of the washers stick to the plate (A good thing) and others fall out and roll around the floor. I also usually take the top front screws off as well and clean everything up. (Basically, I remove the plate)
I'm pretty happy with my plate as it is pitted pretty good from rocks-so it's doing its job.
Thinking of doing the same.How much of a PTA when changing the oil?
It comes of pretty easy, but like GreyMotion said, the little rubber grommets between the side plate and bracket are a pain to get lined up right. I fixed this last time by just super gluing them in place and let it dry while I changed the oil.
