Spent most of the day trying to figure out where to put the PC 8 so the seat wouldnt interfere with the relay or PC 8. Eastern Beaver shows a 2012 installation but its right in the middle of the box under the seat, so anything else I would put in there the PC 8 would be in the way, so this is how I installed it. The PC 8 just fits on the side, screw in using the bottom holes of PC 8, the top holes should just be showing above the storage box. Place the relay on the left side of the frame using zip ties as shown, the wires from the relay should go under the frame as the seat has some rubber supports that sit on the top of frame. feed the negative wire between the storage box and the ABS fuses, feed the positive wire thru the rubber cap, cap intrance will stretch enough to feed thru, then run the 3 other wires going to the PC 8 to the notch as shown, might use another zip tie there to keep the wires from rubbing on the metal bracket. With this installation there is about 1" of room to feed wires on bottom of fuse box and at least 1/2 inch from top of fuse box to seat bottom. Im new at this so if you see something wrong please let me know. Thanks
