0
Hey every one,
I got this dl1000k4 a month ago. It had 14k miles on it and I don't think it was making any noise like it is now.
I didn't know what type of oil the previous owner was using so I used regular 10-40 like the book says.
The next time I rode the bike I noticed an inconsistent knock that is only aparant after the bike is good and hot.
I found out that the previous owner was using a synthetic so I changed it again, new oil and filter and it is still knocking.
Any one out there have any suggesitons?
Ryan
K
Discussion Starter #2
Does it occur while at idle? If so, it sounds like idle hammer. Do a search for it and you'll find it is pretty normal, but can be reduced by different motor oils.
0
Yes, this is most obvious at idle, above that it is hard to tell if the noise is there or if it increases w/ engine speed,
Thanks, I'll theck it out
Clutch in our out!!! Didn't I ask this in the "other" form???? :lol:
0
clutch in - the noise is there, and I let it out and it seems to get a bit louder, or more noticable
