1 - 15 of 15 Posts
Wondering about tall rider mods for my bike?
2012 DL650A
I'm 6'3" ish
I currently have 30mm (inch and a bit) straight risers on, what I believe are, stock handlebars.
In a standing position I'm definitely bent over further than I'd like to be. It's uncomfortable to ride more than a few minutes at a time standing up.
I previously had Rox 2" risers in the up and back position although I think now I might put them back on in the up and forward position if I can work that out.
I will also order the 1" foot peg lowering kit, which should help. I'm just not sure that will be enough.
Anyone my height, or taller, have experience with mods to improve stand-up ergos?
Adventuretech's footpeg and shifter lowering kit. Footpeg and Control Lowering Kit - AdventureTech, LLC.
RichlandRick is a regular contributor here.
You might also consider a handlebar raising kit but many tend to purchase a higher Adventure handlebar to also get wider bars which offer more leverage if you intend to ride unsealed roads. Most such bars tend to be overly wide with markings to cut them back to your preference.
I've got the same Rox risers installed up and a bit forward. Also have a peg lowering kit. Stock bars. I'm 6'2", long torso, and long arms, so this setup improves the ergos when sitting and standing.
I was amazed at the effect when trying to stand with the normal pegs vs. the peg lowering kit (and gear extension). I had no idea it would make that much difference. However the sitting position doesn't seem that much different but every little bit helps. When I had the seat redone by Terry Adcox he also move the seating position back 1 inch (he normally would have moved the seat down 1 inch also but I told him to keep the seat at the same level as stock). I also added the 1 inch Rox risers (the most I could do without changing the front brake hose). I'm 6'2".
I too am 6’3”, 2012 DL650A. I’m using 2” Rox risers, +2” SS brake line, Adcox seat, Adventure Tech peg lowering kit. Currently only using as a touring bike. I had to roll my risers and bars back after getting the Adcox seat as the seated position was moved aft. If you are using a stock seat you can maximize the bar height for standing up as the seating position is more forward. If I were ever to do light off road I would put stock seat back on and roll bars up/forward.
Standing riding is illegal in some states. Be careful and check local laws.??
Leo’s are welcome to ticket me to their hearts content, as I won’t stop standing while riding anytime soon. :wink2:
I get feedback all the time that the peg lowering kit and handlebar risers (we don't sell handlebar risers right now) make a huge difference in comfort when standing.
I’ll be ordering the peg kit. Already have your fork brace (that was yours, right?)
Here's a video about ergonomics:
And remember that you shouldn't be standing like a prairie dog, your arms should be bent, and your legs should be loose.
And here is one on standing postures just in case:
Discussion Starter #14
I just put the Rox risers back on in up and forward position and already it feels much improved. I'm sure adding the foot peg lowering kit will get me to (or very close to) where I want to be.
6'-3" here. Risers (1" up /back) and peg lowering helps for sure. I also run the ATV-sport bend bar that I think helps with the posture and positioning too (a little higher and straighter across than stock.) With the three of those I can stand quite comfortably.
1 - 15 of 15 Posts
