I considered the Pro Taper bars first and decided not to use them due to the smaller inner diameter of the bars. It would have required me having to make/find different nuts and expansion for my stock bar end weights. Instead, I went with MSR ATV High Bars. They were cheaper to buy and they fit with my stock bar end weights. They fit on without me having to change wiring or the front brake line although the brake line is a tight fit. I expect I will order a new longer front brake line (or an extension from SV Racing) before very long as it kind of bugs me.It appears to be a straightforward enough process to take off the originals and put on Pro Taper SE ATV High Bars.
Does anyone have a word of advice before I attempt to switch over to the new bars? Any possible surprises that I need to prepare for? The info I've come up with is a bit sketchy on the details.
If I had it to do over again, I would still go with the MSR's.
