Any sort of loctite, you cook the bolt to 450f or 550f. Melts. Good luck, that looks cunty to do.
Here's a thread the OP started back on June 13th about torque wrenches.Cobalt left hand drills and an extractor. The important point, all extractors do is grab the bolt so you can rotate it out, DO NOT LEAN ON THE EXTRACTOR. If it won't move just use the next drill size up. They almost invariably just back out on the drill for me.
Work out how deep that bolt goes and mark the drill shank so you don't go too deep. No need to heat the bolt if you do that, the drilling will get it hot enough to melt locktite.
The Chinese eBay kits are quite good.
And as a comment, don't use a torque wrench for things like that and certainly never trust the 'click'. Buy some steel and aluminium bar stock, thread some bolts into it then do your best to break them, just so you have a feel for what's 'too much force'. Even the manuals have incorrect torque specs now and then.
Taking it too a shop may well work out less expensive for you.
And an apology if that sounds harsh, I've obviously had to do similar in the past because obviously I have used screw extractors. I'm just annoyed because this almost always happens when someone trusts a torque wrench more than 'feel'. There are some areas where a torque wrench is appropriate, almost all of those are inside the engine, not on the outside.
Yeah, I thought maybe I was missing something as to why the sprocket was still on while all this was being pondered about removing the broken bolt. Get that off/out of the way first and see what you can get ahold of. Ive also cut a slot into a bolt with a Dremel or angle grinder to torque out a broken bolt/stud. Whatever it takes w/o doing more damage in the process.Pull the sprocket off and then grab the end of the bolt with a vice grip. Apply some heat and spin it out.
Although the bolt broke, the speed sensor rotor itselfPull the sprocket off and then grab the end of the bolt with a vice grip. Apply some heat and spin it out.
In fairness to myself, I was trying very hard to do things "the right way." I have two torque wrenches, the smaller one didn't have a high enough torque capability for the speed sensor rotor bolt, so I opted for the Big Mama (the huge 24 incher). It was my first time ever using a click-style torque wrench, and I effed up. But only through ignorance, and sometimes that's the way we have to go to learn.Here's a thread the OP started back on June 13th about torque wrenches.
Is there a shorter version of this torque wrench?
I need to make some adjustments to (or possibly replace) the chain on my 650 XT. I saw that the rear axle nuts need to be torqued to something like 145 Newton meters (or 150 foot pounds—don’t have the service manual in front of me). I bought this wrench, and when it arrived, was a bit shocked...www.stromtrooper.com
As they say, you can lead a horse to water, but you can't make him drink!
Look up the Suzuki part number on partzilla. As I recall they embed the size in the part number.Does anyone know how/where I can find out the size of the hex bolt for the speed sensor rotor on a 2015 V-Strom 650 XT? I know it's a 6mm hex head, but I don't know the length or thread "size." I'm obviously going to need a new one, assuming I get the broken one out. I don't see the specs for it in my service manual. Any help is appreciated!
When you get the stud out hold the broken bits together and measure them. Then go to the local hardware store and get a new fastener. Lowes/Home Depot usually have unfinished carbon steel Allen bolts or possibly even a plated hex head cap bolt will work.Does anyone know how/where I can find out the size of the hex bolt for the speed sensor rotor on a 2015 V-Strom 650 XT? I know it's a 6mm hex head, but I don't know the length or thread "size." I'm obviously going to need a new one, assuming I get the broken one out. I don't see the specs for it in my service manual. Any help is appreciated!
Looking at @oldjeep's pic, you want an M6/1.0x8mm Allen head bolt M=metric, 6 =6mm,1.0 = thread pitch (distance between threads), x 8=8mm long thread. If when you get to the big box store, that looks to long or too short, buy an extra -x6mm long or x10mm long; they're cheap and they only come in even number lengths.View attachment 305150
So, looks like 25mmSuzuki 07130-0825B - BOLT | Partzilla.com
Buy Suzuki 07130-0825B - BOLT. This OEM part is guaranteed by Suzuki's limited part warranty ✓ FREE Shipping on qualified orders - Partzilla.comwww.partzilla.com
This cracked me up!!!>>24" torque wrench on a 6mm bolt is like swatting flies with a 105mm Howitzer.
