For the last 2 years I have been riding my strom 1000, and 1 in 10 changes it would false neutral between 1st and 2nd. Annoying but I lived with it.
I use to hold the adjuster up in second as it used to pop out more if I did not.
Then I thought the other day in what can only be described as pure brilliance "I will look at the adjuster". Looked good , but I though what the heck will adjust it out so the throw is a little higher off the boot. In other words raised the adjuster so the level went up.
Went for a 200 klm ride on the weekend. Not one false neutral.
Hope this helps others if they get a lot of false neutrals., sort of counter intuitive, as I create less pressure on the adjuster in my mind , but it worked.
Cheers
Mike
