Hi,
I have too many unswitched (hot) devices connected to my battery terminals right now: GPS (I want it unswitched), battery tender, stebel and coming soon the coocase S50. 3 terminals on the battery work, 4 would not - they are too thick.
The EB solutions (PC-8 or 3CS) aren't really what I need as they mainly provide switched terminals and I want more unswitched terminals.
So I was thinking of this simple solution, please let me know if it makes sense and/or is safe:
Get posi-lock connectors (e.g. PTA1416 or PTA1218, need advice here) and then connect the narrow side (e.g. 16) of the posi-lock the single battery wire, and to the wider side (e.g. 14) 3 wires, therefore splitting 1 to 3.
This should take the load off the battery terminals.
Of course, each of the splitted wires is protected by its own fuse (just like it is today, I only want to solve the battery terminal crowding).
Any advice, idea, comment is welcome.
The eastern beaver PC-8 uses an external relay. If you do not want to have them all switched, you can either skip the relay, or switch which power lead uses the relay amnd which is direct.
A fuse block is still the easiest solution to the "too many connectors at the battery terminal" problem IMO.
Alternatively, the Fuzeblock FZ-1 makes each circuit selectable as to whether it is switched or not.
