1 - 10 of 10 Posts
I would like to put my front rotors on a Blanchard grinder, as I have with rotors from other bikes, in order to remove a slight warp and any residue.
In order to have a nice flat piece of metal (the rotor) which can be placed on a Blanchard grinder, I need to remove the rotor from the carrier. :confused: The rotors attach with some kind of round buttons that don't appear to be removeable.
Can the rotors be separated from the carriers, and then re-attached? How?
Thanks for your advice.
Resurrecting an old but relevant thread here.
I have an otherwise perfectly good front brake rotor on my Vee that has lost the wave washers that hold the buttons tight. In a short period of time, the rotor has developed a disturbing amount of rotational play (not just side-to-side) which has resulted in some "grabby" braking and unpredictable feel.
After researching a way to replace these buttons, I have found no solution for the Vee - only BMWs and Ducatis. It pains me (and my wallet) to toss away a good rotor. It has hardly any wear on it other than the buttons, and perhaps the carrier where it has worn against the buttons.
In the meantime, I have mounted an old, almost worn out rotor while I think about what to do.
If I could replace the buttons, I'd be a happy camper.
Any ideas?
Or failing that, if anyone's got one kicking around, I suppose I could use a used rotor...
$400 CDN for a new OEM rotor. Fuuuuuuuuuuudddge.
1 - 10 of 10 Posts
