1 - 13 of 13 Posts
Hi All,
Since 3 weeks I am the happy owner of a K7 650 ABS and have put 3000+ km's on the odometer since. I love this bike!
The bike had suzuki engine guards on them when I bought the bike, and I want to replace those with the larger SW Motech ones. But, I cannot seem to remove the current engine guards. There is a large bolt and nut that seems to go all the way through the engine block (seems a risc when the bike falls over and force is applied?). The nut is ridiculously tight! And I cannot seem to get it removed.
I tried applying heat (from a lighter) to it, sprayed WD40 on it, but it seems to be rock solid.
Does anyone have any tips/tricks on how to remove those engine guards? I can't find instructions on my local suzuki website, or google.
Kind regards,
Arno
AFAIK there are no OEM Suzuki engine guards. What you probably have is a third party product that was sold by the dealer when the bike was new.
A couple of photos will greatly assist people in helping you.
Discussion Starter · #3 · (Edited)
Well, I believe they are originally made by SW Motech, however they are sold (here in Holland at least) by suzuki as an "official" accessory (sorry, the page is in dutch, but the images are universal ;-) ):
Accessoires - Suzuki Motoren
The bolts connecting the top of the guard to the frame are easy, but the lower mount point is a very large bolt going all the way to the other side of the bike where it connects the other engine guard. And that is the one that is stuck.
Regards,
Arno
Are you applying a wrench to the bolt head to hold it in place while using another wrench on the nut? The installer may have applied a thread locker. It may help to heat to the nut side to ease the dis-assembly but a long breaker bar or a length of pipe over the wrench should be enough. You'll need to replace the SW-Motech through bolt with a stock one.
Discussion Starter · #5 ·
Hi greywolf,
thanks for your reply. Yes, I applied a wrench to both the bolt and the nut (applying force in opposite directions of course) and did apply some heat from a lighter to the nut. But maybe that was not enough heat. I will try using a soldering iron tonight.
I did consider using a piece of pipe on the wrench to apply more power, but was afraid I was doing something wrong and maybe breaking something that way.
Once removed, I was thinking about using the same bolt again, but without the engine guard. Is there anything particular about the stock bolt (which I do not have as this bike was delivered with the engine guards on it when new).
Regards,
Arno
The stock bolt is significantly shorter than the SW-M bolt. To use the latter, you would have to keep the spacers and possibly add washers to make it work.
Discussion Starter · #8 ·
Ah, makes sense. I will see if I can order the stock bolt. However, it seems that the bolt goes through the engine block, but is only used to hold the engine guards together. It seems that behind the nut there is a hollow screw/nut or something that connects the engine to the frame? So, I was not entirely sure if a new bolt was needed at all.
That's an adjuster to provide the proper containment of the engine in the setup stage. The bolt is needed when riding.
Discussion Starter · #10 ·
Very informative, thank you! I will get a bolt than :) And not yet having a service manual, I would guess that specific tensions are required when fastening the stock bolt? I will probably wait with finishing this once I get the service manual..
The table is at VSRI. It's a more technically oriented forum.
1 - 13 of 13 Posts
