1 - 2 of 2 Posts
You will need to drain the engine oil, and the coolant before disconnecting the radiator hose and removing the RH footrest assembly. There are some other connections at the front of the clutch cover as well - the oil cooler hose and crankcase breather.
1 - 2 of 2 Posts
