1 - 10 of 10 Posts
Where is the horn located on the DL1000? I found a nice guide that showed the horn on the DL650, but on the DL1000 there's a big fan in that spot...at least that's what it felt like when I stuck my finger up there. I even tried looking in the service manual and couldn't find it. Sorry for asking, but I need to know where it is before I start taking things apart. Thanks.
The Horn Is located on the r.h. side of thr rear of the radiator . good luck
Thanks for the info!
are you serious? why not press the horn button then look where the sound is coming from
to gain access you need to remove the temp sender plug (not the assembly . . . just unplug it.) bend the shroud back and that'll give you enough room.
there's a big fan in that spot...at least that's what it felt like when I stuck my finger up there. .
I hope it was off when you used your finger as a fan probe! ;)
Believe me, I didn't want to ask, but the engine was hot from my morning ride and I knew it involved taking either left- or right- side farings off. The DL1000 has an extra hunk of plastic on the fairing that makes it difficult to remove when you have crash bars.
1 - 10 of 10 Posts
