1 - 4 of 4 Posts
Yall-
I'm installing me Stebel Horn - and I want to remove the side fairings (not the upper black fairing that comprises the windshield / gauges assembly). Does anyone have any tips on this? Any links I could use to help me. Seems easy enough - yet, she's still together :(.
Tanks
Mates
There are a couple of sort of hidden screws in the little grill things. Phillips tip screwdriver to remove. There are also a couple of those black pop rivets on the underside above fender as I recall. Push the center of the rivet to release.
I am also assuming you removed the crome hex head bolts on fairing itself and on the strip between fairing and dash?
A good source of this stuff is the shop manual. There is a link several places in the forum but I can not fid it just now.
Yep. Removing the chin piece first is the key. Its removal provides access to the screws holding the fronts of the side panels.
Be sure you know where all the screws and rivets come from. I thought I was being very careful but ended up with an extra after I got everything put back on. I should have taken pictures or at least written some notes.
1 - 4 of 4 Posts
