Alright, I installed (sort of) a Fiamm horn on my bike. I have a ground wire going from the battery to the horn and the power wire running to a relay. I have tied into the existing horn wires and run those to the relay as well.
Now according to everything that I have looked at this should make the new horn sound, but all I get is the old horn. I have checked and I have power at the relay from both the battery and the existing horn. I can make the relay 'click' when testing it, but still no horn.
Does the amperage of the relay matter? Do I have to wire the relay differently since the DL650 horn switch is on the ground wire?
Any help would be appreciated.
You must have it wired wrong. The bottom wires go to 85 and 86. The top wires go to 87 and 30.
Fixed it!
Thanks for the reply Greywolf.
I did have it wired correctly but my ground wire from the original horn was loose. Works like a charm now!
Well, if the wire was loose, it wasn't wired correctly. :new_shitsmiley:
