1 - 17 of 17 Posts
138 less than a Stebel! :cool:
It can't be measured on any conventional db meter, there isn't enough volume. You need to use a Stethascope to hear it.
Anyone know how many db's the weakass horns put out on the Vee's?????
Mark,
I actually have a dosimeter and I'll try to remember to measure it tonight....I think they measure it at 10 feet..........
Jeff
Jeff, I was looking at at www.ridesafer.com as they have lots of horns and they measure at 4 inches!!!! seems weird but anyways, they have horns that are 125, 129, 134, and 139 is the Stebel. I bought the Stebel but havent installed it yet. I am worried it might be too loud especially when I give a warning beep to my buddies on harleys that I am coming by to play with the corners. They have me do that on my Bandit and when we ride thru cranberry bog country there are twisties thru the bogs and no side streets for danger and you can see for 1/2 mile in most directions and I figure getting off into a bog wouldnt be so bad!!!!
If all these after market horns are in this range above, then I expect the strom horn is MUCH lower. Knowing the stom's dB's would help me make a decision, etc.
I just read another post about using the headlight flasher switch for the Stebel and keeping the stock horn/switch and I like that idea alot!!!!!!! That would be easy to do too.
Whistler, sorry for my reply to you,,, I misread your post and I agree one dB sounds about right!!!!!!!!!!!!
riding home last night on the highway at 90mph I tried horn several times and I can barely hear it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
So, Jeff i would love to hear what you measure, at both say 1 and 10 feet???? Thanks in advance!!!!!
Is it really 138 Whistler or are you joking with me???? Do you have a Stebel???
Riz
Had it since day one. Can't recommend it enough. And technically, Stebel rates it at 139 db.
Jeff, I was looking at at www.ridesafer.com as they have lots of horns and they measure at 4 inches!!!! seems weird but anyways, they have horns that are 125, 129, 134, and 139 is the Stebel and keeping the stock horn/switch and I like that idea alot!!!!!!! That would be easy to do too.
Mark,
I tried this morning but I need to replace a couple of 9volts to do it...I'll pick them up over the weekend and post up the #'s
Jeff
Is it possible to run 2 stebels? I wouldn't mind one in each side of the fairing. I imagine it would gain another 2-3db?
OK, no rush! thanks
Mark,
[email protected] one foot it measured our at 107 DB and @ ten feet it was just over 100DB.......
Jeff
as a comparison, I can scream at 105DB........we may as well holler at a car<LOL>!!!
press any key to continue
...If all these after market horns are in this range above, then I expect the strom horn is MUCH lower. Knowing the stom's dB's would help me make a decision, etc.
I was also concerned about the Stebel being a bit too loud for some situations, so I put a switch on it (off = normal horn, on = stebel + stock horn). The Stebel is pretty loud, but isn't too loud in my opinion unless you are sitting in a confined area like a garage.
Some pics of how I mounted things...
Discussion Starter #17
Thanks Jeff !!!!
That stock horn sure is low level!!! I am definately installing the Stebel !
Thanks!
1 - 17 of 17 Posts
