Try replacing the rubber with nylon washers or spacers, a cheap substitute is to cut some shapes out of an old plastic cutting board.
On the inside of the plate under the bolt head I put upto 3 washers that progressivly get larger this will put a large surface area on the inside of the plate = no flex
I also inserted a piece of thick rubber bicycle tube between the plate and both the upper and lower the mounting brakets
I have no flex in the pegs i think due to the larger washers and no vibration due to the bicycle tube which is crushed flat..... this worked for me
hope this helps
hope this helps
