I've got a Monimoto 5 and I've placed it in a neat area underneath the seat and under a side panel but it's not that hard to find, the space under the seat looks quite cramped to start with, has anyone got any better suggestions where to place it? Preferably without needing the take the bike to pieces as it needs to be accessible for changing the batteries once a year etc.
2022 V-Strom 650
I have been thinking about this (not that I was going to fit a tracker as much, as say, just thinking as I was doing other things with the bike! I don't know how big the MM5 is, so ymmv with these locations.
You could try and hide it down between the fuel tank and outer cowling (if there's enough room), there's a big harness on my '17 that runs down the LHS as you sit on the bike (you can see it if you peer down the hole where the steering is). A lot of metal in the tank / frame though there to interfere.
Another place may be behind the dash - follow instructions for changing the headlight, there's a metal frame in there you might be able to sneak it into/secure it, and when buttoned all back up you wouldn't know it was there.
A third place (but just a theory from me), if you were to block the EVAP system off, leave all hoses, etc, in place, and remove the canister innards and place it in there. No idea if that'd work, although i've read a few people have removed this with no ill effects to gain more under-seat storage space. Not something you probably want to do on a 2022 bike.
