Pretty sure it's mainly going to be software so probably have to write new code and flash the ECU to make it work.
The bike is "Canbus" so all the inputs you mention above are available in the system. I'm sure the almost all of the existing switches on the handlebar can be repurposed for different functions as that is what is happening on my DL1050. I'm sure it will be a matter of software for the most part.Having all the safety features could be the issue.
Clutch switch, brake light switch, over speed, under speed.
I know my MC cruise goes through a number of checks before it can be set.
EG; it will not set until I have used my brakes, it needs to know the brake light system is good before it can be set.
