1 - 14 of 14 Posts
R
Here are some pics of my datel voltmeter and the location of it.
RR
How bout a pic in the day time so we can see what it looks like and how you mounted it?
Oh, and a pic of your Date too....:cool:
cheers
I also have a Datel installed.
It consistently reads 0.5 volts lower than actual. I have verified this with 2 different hand-held voltmeters.
So, it is precise, just not accurate. Who cares? I can easily add 0.5 volts mentally.
Living the Stereotype
I thought you said DATE!
I was looking for a girl's picture.
I'm sure Mrs. Ridgerunner would have a keen interest in that photo, too.
Where are you getting your power from? Voltage will drop with wire length and size. I'd guess that if you connected a decent size wire set directly to your battery, that you'd get a correct reading.
If not, it should be returned so that you can get an accurate one...
R
I dont know what Enigma has but I am running 16 ga. straight from the battery.
RR
R
U are right about that, if she could catch me I guess U would find my nads somewhere around the Highest Point on BRP where she kicked me in the groin :(:(:p/
RR
R
cheers
If I can remeber I will get U one. But I just mounted it to the underside of my Pat Walsh Radar shelf. Used super 3M tape and then just made a lil bracket out of some aluminum we had laying around at work.
RR
Voltmeter
What model is the meter and where do you buy it from?
1 - 14 of 14 Posts
