1 - 9 of 9 Posts
I ride early and late season and the road chemicals have done a job on my fork tubes. I promise to try and get over my phobia of washing the bike and will use a corrosion preventative (probably Boeshield T-9) on the tubes after they are clean, but does anyone know how to properly clean off the corrosion already present? I do know that steel wool is a very bad option (tried it once as a youngster with bad results) but am not sure where to go from here. There does not appear to be any pitting or scaling. Any help would be greatly appreciated. Thanks!! :confused:
I would try chrome polish.
It looks just a bit like there's either a hole or a reeeeaaaally deep, rusty pit in the middle picture.
Is that as it appears?
Yup, that looks like a hole. Could be the angle or the light, but it looks like a hole to me.:yikes:
000 or 0000 steel wool will remove the corrosion and not harm the good metal. You can use it safely on chrome as well.
Once you have it back to good metal, you can maintain it with "Nevr Dull Magic Wadding." It's a marine product that cleans metal and leaves an anti-corrosion coating.
http://www.nevrdull.com/
I have been successful actually sealing leaks etc by super cleaning
dressing with like 800 grit
Filling the "hole" with jb weld
Dressing down the area with block sand paper 600, 800. 1200 then metal polish
If the wiper/seal never gets there just paint that area
I would go with chrome polish first and maybe very fine steel wool if this does not work.
They need to be re-plated. I'd ride into a local chrome plating shop and ask about that. Be sure the shop knows that the tubes need to be returned to the original outside diameter. You'll need to disassemble the forks yourself, or have someone do it for you, not the plating shop.
1 - 9 of 9 Posts
