Hi All,
I have abbot 350 miles o n my 09 Vee and I have noticed a spot of oil on the floor under the bike. After a good look I have found a drip of oil coming off a fitting on the front cylinder above the starter. The manual says it is the cam chain tensioner...
It says that it should be tightened to 16.5 ft/lbs but without removing the cooler I cant get a torque wrench on the bolt. I put a 12mm wrench of it and it did turn an 1/8" maybe.
Is this something that is an issue with the Vee and do you think I should take it in under warranty?
Mark
