Fuse sizing is best done for at least 20% over the device draw yet not enough to let the wiring overheat. The voltmeter and temp gauge draw very little power. I like a fairly heavy wire on a voltmeter for best accuracy though so would probably go for about 16ga with a 5A fuse. You can run both the voltmeter and temp gauge off the same wires to save space on the PC8. A phone charger doesn't draw much either. 18ga is typical and a 5W fuse is plenty. The GI Pro attaches to a specific connector on the bike's wiring harness. It won't connect to the PC8 at all.Here's my three questions:
I noticed that the voltmeter and temp gauge don't come with any wiring so I was hoping to get advice on the best way to connect those to the PC-8 and amp level?
The other question is has anyone connected the tank ring wiring to a PC-8 and what amp did you use?
Last question is connecting the GI Pro Indicator to a PC-8 and amp level? Have any of you done this?
