1 - 3 of 3 Posts
Ok. I've read everything I can find in posting pics. I'm using flickr but no matter what I try I get nothing. Can u still use Flickr? Should I just try something else? Thanks
Flickr recently changed. What I do now is to call up the picture I want to post and click the "share this photo" icon on the right.
Then I click the BBCode icon. Then click on the size listed below that and the available sizes will be displayed. Select one. If you change size, select the text that is provided. I hold down CTRL and press C. If you don't change size, you have to select the text manually like you would in the first step of a copy and paste and then press Ctrl-C to copy. Then click in your post where you want to paste the picture and press Ctrl-V to paste. You can also use the browser's edit menu to copy and paste.
Here's an example:
CC4 3 by Greywolf, V-Strom rider, on Flickr
I usually eliminate the stuff before and after the image tags to leave out the byline but I'm getting tired of that. I've added a space after the first image tag in the following post to show what the code looks like but the url tags disappear from what you see on the Flickr page.
[img ]https://farm4.staticflickr.com/3287/2721055694_2f6721043c_m.jpg[/img]CC4 3 by Greywolf, V-Strom rider, on Flickr
Yay! I figured it out. Yes actually had trouble even with your input. Thanks for the help.
1 - 3 of 3 Posts
