1 - 10 of 10 Posts
So, I understand there are pre-wired keyed hot factory wire connectors to hook up the "Suzuki" heated grips. I haven't bought the very reasonably priced factory heated grips ($310 - HA!), bit I'd like to find those connectors.
Anyone know if this is true and where they're at??
Not sure where located, but I highly recommend the Symtec grips.
Oxfords are great. The factory connector used to be behind the radiator, IIRC.
Dealer is requesting install PDF on the '14 grip kit. I'll advise once I get it.
I had the Oxfords installed on the Vee2. Riding at near 0 degrees Celsius, fingers are warm without the hand guards in place - still waiting for the SE part to arrive :furious:
I installed heated grips from Cycle Gear and the factory connector was neatly and tightly tucked behind the radiator. If you don't want to splice into the connector you can purchase a wire,horn,lead and connect that way.
Reference this article as it has all the info you need.
http://stromtrooper.wikispaces.com/Basic+Strom+Wiring+101+(DL1000+&+DL650)
Was yours a 2014? I know the pre-2014 models had wiring behind the radiator waiting to be used.
1 - 10 of 10 Posts
