1 - 3 of 3 Posts
I've got an '09 Wee (with ABS) and am looking into using a horn lead attached to the unused heated grip connector to get switched power to a DC power outlet I'm installing.
I know there are several posts here about locating the connector, and I thought I had found it, but now I'm thinking what I actually found was the rear brake light connector. I've attached two images showing it's location and the connector itself. Looks like the connector *could* accomodate up to 4 wires, although it just has two - Orange/Green and Black/White.
It had a black rubber cap on it, and it wasn't taped down to anything.
Thoughts? I'd ideally like to find the Heated Grip connection so I can use a horn lead to cheaply and non-permanently tap power.
That's a new one on me for a capped connector. The wire colors are right but the horn lead won't fit. The OEM heated grip connector is behind the radiator.
1 - 3 of 3 Posts
