Hi guys. I stripped my 07 dl1000. But just side covers and tank. Pressure washed and reassembled. Now when riding the “check” is constantly on and the heat bars is full. Is there a sensor that is can check. Tank you
Pressure washing is one of the worst things you can do to a bike. Now you see why. You'll have to unplug all your connectors and dry them out with a hair dryer or let them air dry for a few days. Then apply dielectric grease to the surfaces of the connectors where they butt together so the terminals inside them are sealed and protected from future exposure to water. Then cross your fingers and turn on the ignition.
Also, as I recall the full heat bars is part of the "check" warning to get your attention and is not necessarily related to overheating or a specific sensor.
Once you get it all dried out, if the check doesn't resolve you can try getting the fault codes from the ECU with "dealer mode".
You must ensure that all of that moisture on all electrical connectors is dried off otherwise this will come back to haunt you in the months/years ahead. Pull all the plugs and spray with electroclean or similar. Dielectric grease is also a good idea.
A forum community dedicated to all Suzuki Strom owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, purchasing, reviews, accessories, maintenance, and more!
