1 - 3 of 3 Posts
E
Discussion Starter #2
Okay, I've found the headlight wire that feeds into the fuse box.
But I need to locate the wire from the neutral switch, and tap into it, and I don't have a wiring diagram.
I can't even find the bloody neutral switch! Given that the gear position is monitored (O/D light, speed limiter in 5th & 6th), is there an actual neutral switch, or is it detected by the computer? Anyone know what colour the wire is, and where it is located?
Not sure about the Strom, but with most bikes (incl. Hondas) the neutral switch earths the wire.
1 - 3 of 3 Posts
