1 - 20 of 27 Posts
Used to on my 90 Honda Transalp and felt it did increase my visibility. Here, some hate them and some swear by them. NTSB testing has shown conclusively that they do work to make other drivers notice motorcycles equipped with them.
Site Search Results for Headlight Modulator
Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums - Search Results
There are other ways to get noticed that are not nearly as annoying to those who are doing the noticing.
Wear hi-viz gear. Put some extra lights on the front for conspicuity (I've got a pair of Denali DM1 (I think that is the model) and a pair of Photon Blasters).
Do the SMIDSY weave.
I think it's a fine line between useful and annoying.
I just bought and installed the Signal dynamics modulator, and I found that my headlight was turning completely on and off, not the dim/on it is supposed to. The full (or close to) off/on flash is definitely way annoying, even to me seeing the reflection off other cars. That said, the faster flashing rate on the SD module (which is dim/on due to the higher frequency) looks alot less annoying and much more obviously not me blinking at someone (as has been discussed in other threads, of people thinking you're signaling them to turn in front of you or something like that). After a couple e-mails with Signal dynamics, I found the following things:
1. The SD modulator only works with incandescents (OK, it says this in the small print...)
2. The reason for #1 is because the modulator just pulses the power to the headlights on and off completely, and it relies on the slow cooling time of the incandescent filament to prevent the bulb from dipping below the 17% lower limit from FMVSS108 (federal reg)
3. My modulator flashed at 2.76Hz. FMVSS108 states the frequency requirement as 4 + 0.66Hz (240+20BPM). So the SD modulator is not actually legal :furious:. This appears to be maybe a recent quality problem for them. The guy at SD confirmed the low frequency himself, and I measured the frequency with a Fluke DMM, so I'm 100% certain that the frequency is actually low. SD said that they don't have access to the source code of the headlight module, so they can't update it to fix the problem :confused:
4. SD is releasing an LED compatible version this summer sometime. I would assume that this module will not flip the power on/off, but more of a 100%/33% type cycle, or something like that. I don't know if their frequency circuitry will be any different, but maybe it will be
5. The switching schemes built into the SD modeule are very nice. You can switch modes with 2 honks of the horn (if you've hooked up the heads up horn wire). You can also turn the modulation off by flashing the brights for less than 1s duration. I am able to just turn off the modulation right now with the defective unit, so that is really nice. I'm pulling it off the bike tomorrow and returning it.
Anyway, just thought I'd share that interesting info on the newest headlight modulator thread. I think I might wait for the LED compatible module this summer, as I can't find any modules with the coll features of the SD one for less or equal price.
Super Moderator
I've witnessed three SMIDSY situations where the rider almost got taken out by a car and one where a bus tried to pull into the lane of the motorcycle. In all those cases the bikes had modulators on and it appeared the car driver thought they were being given a go-ahead by the bike.
For me about the only time I would want one is while passing multiple cars as in that situation there is never a reason to come over if there is already someone there passing.
Just removed the Signal Dynamics Plug and Play Headlight Module after about 4 months use as I was just TOO visible for my (and other drivers') liking. I'll stick with bright colors and flashing the headlights manually when needed. My "safety first" wife isn't too happy about it though. If she had it her way, my Glee would have training wheels and airbags. lol
I also installed the brake light module which I DO like and keeping. Works great!
I also have a brake light flasher (3rd brake flasher brand) on both my bikes, and I like it. The one I got is extremely customizable, and has a second flashing pattern for when you hit the brakes hard (G-sensor built in). It's only $30 too... You just have to wire it yourself, but that's not hard if you just buy an extra connector for the tail lights and create a plug and play connector yourself.
Anyway, FWIW, I returned the signal dynamics headlight modulator I discussed above, and I have since converted to LED headlights. My LED's throw alot more light up, though they still have the distinct line across the pattern in the right spot, so I think I have it adjusted correctly. I haven't had any cops pull me over despite passing a number of them at night, but I have definitely noticed they throw more light above the line.
I also feel like people see me much better now too. I feel like I get fewer SMIDSY situations now, so I'm pretty happy. I probably won't get a headlight modulator when the LED ones come out as I don't feel like the marginal benefit is
Super Moderator
Strangely having headlights that are too bright can be counterproductive as well. Sounds like you are on the right track, just be careful with the aiming. If they are throwing light directly into driver's eyes (like high beams) then you may be effectively hiding your location, your speed and what kind of vehicle you are riding. These factors can make a huge difference to the driver's ability to perceive your presence.
Agree
+1
I think they piss people off, they do me when one is behind.
What's next, revolving yellow beacon on helmet?
:cheers2:
I agree, obnoxious, however I am looking at adding a brake light modulator. Just have to decide which one.
Agreed. I try to look for where the "line" lands on peoples' cars that I am behind when I stop at an intersection to make sure it's on the trunk and not in the window. I haven't noticed any clear cases where it was too high (at least compared to my 4runner), so hopefully I am no blinding people. I have looked at it myself, but not yet while driving my car oncoming, so I don't know 100%. I should get someone to ride my motorcycle at me while in my car to see for myself what it looks like.
Headlight modulators are a great tool for splitting lanes. That said, I never use them unless splitting or coming up on someone making a turn for added conspicuity. On the rare occasion I get on a canyon road behind a totally oblivious driver and I will use them until the twit notices me and lets me pass.
Will they stop all possibility of having an accident? Of course not! But used sparingly they are, IMHO, a very useful tool.
I am also considering adding an accelerometer to my brakes to make them flash when I back off the throttle but don't hit the brakes.
Agreed, if someone leaves the headlight modulators on while in traffic it is indeed annoying.
Had a headlight modulator years ago on my 84 Goldwing. It worked well and wasn't overly obnoxious. I had people tell me it looked like I had a "short" in the light. it would go, from dim to full on rapidly and I didn't run it all the time.
I've also had brake light Mods which I feel are very effective. I had a set of Hyperlites on my ST1300 and they really added visibility to the rear of the bike . I even had cars change lanes when approaching from the rear at a stop light.
I like the idea of the brakes lighting up upon deceleration without having to actually hit the brakes..... still looking at options there..
Any recommendations? the hyperlites are a little pricey but good quality.
I have a Kisan headlight modulator on my 2012 DL650 and one on my R1200RT. On both bikes I have a pair of fork mounted Ridid Industries Dually LEDs with amber covers. It has significantly changed the driving patterns of those who I encounter, in that I very rarely have anyone pull out from side streets into my path, nor do I have oncoming cars turn left in front of me like in the past. I'm sold on them and I can say that I won't ride without a modulator anymore.
A good compromise is to swop from modulating high beam to low beam. Still visible but less aggressive. Go to high beam to stop the modulation for normal daytime riding and flip to low beam when additional visibility is warranted.
I also run one regular and one yellow H4 bulb and 4 Whelen TIR3 strobe lights (on constant). Looks like a x-mas tree in front, but the more unusual the more you get noticed!
Fine line between being noticed and simply annoying. Would want to be able to turn it off when following a pickup with a rifle rack.
You can turn it off at any time, just switch from high to low beam or vice versa.
It's a very divisive subject. Glad that the sparks flying are somewhat modulated. :wink2:
1 - 20 of 27 Posts
