1 - 4 of 4 Posts
I'm not wanting to debate whether you like/dislike headlight modulators (personally I'm a huge fan), rather I'm simply wanting to know how easy/difficult is installation (specifically of the Diamond Star) on the Strom and what, if any, use issues you've experienced (either 650 or 1000). Thanks in advance.
No worries...no debate. ;)
I don't have the Diamond Star...I have the Kisan PathBlazer Dual unit.
I bought it at www.ridesafer.com
Clicky Here
Easy! Cheesy! Unplug headlight bulbs from wiring...put pathblazers between wiring and bulbs...connect Master to Slave (no whips required)...connect sensor to master. Done.
Note: Don't connect the sensor to the slave unit...then bridge. No Worky-Worky. ;) You can figure out how I know. 8)
hardest part was figuring out where I wanted the sensor. And I'm still working on that. Right now it's zip-tied to a cable run.
Sorry that I can't help with the Diamond Star unit. I'm all about not messing with any more wiring than I have to. ;)
<---lazy guy.
Corpsie said:
What does a headlight modulator do?
The simplest way to explain it is:
It makes your headlights flash. The path blazer model that I have flashes the high beam at a specific rate when the sun is shining.
All headlight modulators are required by law to have a sensor which will prevent the modulation when it gets dark so that you have full access to your high/low beam at night.
That's roughly what it looks like. I snatched that image from RideSafer. They have pretty good prices, and I've always been impressed with their service.
<--- has a modulator on his and her bikes. ;)
1 - 4 of 4 Posts
