Headlamp adjustment
2712 Views 4 Replies 3 Participants Last post by  Motorpsychology
I have had a few bikes were the headlamp is difficult to adjust ..but..the gen 3 650 v strom is by far the worst one i have ever had . Who ever thought of it at suzuki wants sacking . I take my wife pillion every now and then and having to either strip the body work off or lay under the bike with a long screw driver every time i take a pillion "what a ball ache" 😡
Once you've removed & reinstalled the rear cam chain adjuster a time or two, you'll appreciate how easy it is to adjust the low beam.
Body jewelry Circle Jewellery Electric blue Clock
A long shaft screwdriver is good for a quick n dirty adjustment; I remove the instrument cluster and take the bike out on a lonely dark stretch of road and fine tune both beams. The bike will run just fine w/o the cluster and the lo & hi adjusters are easy to get at.
See less See more
Yea i know what your saying but still a bad design that should be a two minute job on any bike .
Hola buenas tardes queria comentarles que para regular las luces cortas como las largas por debajo del faro la parte izquierda con una llave 10-11 de estrella plana o con una 10-11 plana de carraca como digo con el manillar girado un poco para la parte izquierda se hace bien y para las largas igualmente pero girando hacia la derecha un poco el manillar por debajo se puede regular la larga espero que les sea util muchas gracias un saludo para todos desde ESPAÑA
What he said:
Hello, good afternoon, I wanted to tell you that to regulate (adjust) the low lights as well as the long ones below the headlight, the left part with a 10-11 flat star wrench or with a 10-11 flat ratchet wrench, as I say, with the handlebar turned a little for the left is done well and for the long ones the same but by turning the handlebar a little to the right below you can adjust the long one I hope you find it useful thank you very much greetings to all from SPAIN
