Bolts too long?
i have installed handlebars risers on my 1050 xt. After 2500 km, I noticed that the steering wheel shakes quite a bit from the base. I checked all the screws and they are all tight. Does anyone else have the same problem with the risers? the local dealer when I asked said he didn't know. Some mechanics I contacted told me that I could remove the rubber washer and install a galvanized washer for more stability.
In the photo, the red line shows where the steering wheel moves . View attachment 307020
the risers were placed on the easels without me interfering at all at this pointBolts too long?
the risers were placed on the easels without interfering at all at this point. all mechanical parts are factory including bolts.Bolts too long?
I moved the cables/hydraulics to the rear side of the handlebar.Do you not find the right hand cables and hose really really tight on full left lock with 2" risers.
Did you have to reroute cables to get this to work? I would really like my bars to be up and back to really be comfortable. Rox risers would be perfect, but I haven't taken the plunge as I'm worried about having to go through the pain of rerouting all the cables and bleeding the brakes...although, it's probably time for them to be bled.I have 2 inch Rox Risers on my 2020 DL1050 with no issues.
I answered it a few messages ago.Did you have to reroute cables to get this to work? I would really like my bars to be up and back to really be comfortable. Rox risers would be perfect, but I haven't taken the plunge as I'm worried about having to go through the pain of rerouting all the cables and bleeding the brakes...although, it's probably time for them to be bled.
Did you try just tilting the handlebars forward by say 1/4 to a 1/2 inch before installing risers.i have installed handlebars risers on my 1050 xt. After 2500 km, I noticed that the steering wheel shakes quite a bit from the base. I checked all the screws and they are all tight. Does anyone else have the same problem with the risers? the local dealer when I asked said he didn't know. Some mechanics I contacted told me that I could remove the rubber washer and install a galvanized washer for more stability.
