I got a pair of generic aluminum hand guards (just the bars) and the only way they will mount and clear the levers is to mount them the ends of the existing bar ends (rather than removing the bar ends and mounting them directly to the end of the actual bars).
Being new to the Wee I was surprised to find the bar end held in place only by a rubber expansion fitting. On my last bike the bar end bolts were screwed into captive nuts welded in the bars and secured (very well!) with red loctite. Getting them off involved drilling out the screw heads! Very much the opposite end of the spectrum from the Wee system.
Anyway, the rubber expansion fitting the Wee uses doesn't exactly secure the outboard end of the hand guards very well. Even with the screw tightened up all the way it's still easy to rotate the guards.
I'm just wondering if anyone has replaced the stock OEM rubber expansion fittings with metal expansion bolts. They make them for things like putting bolts in concrete. They should provide a very secure mounting for the end of the hand guards (might have to drill out the existing bar ends to accommodate the larger diameter bolt though).
Just wondering if anyone has done this, or if anyone can see a reason why not to do this? Are the bar end couplings deliberately made so that they pull out or the bolt bends if they hit the ground? Sacrificial items so that the bars themselved don't bend?
