https://buy.garmin.com/shop/compare.do?cID=145&compare=compare&compareProduct=309&compareProduct=350
It's down to these two. The 76Cx floats (for when I take it off my bike and go fishing), accepts higher memory cards, and seems to have the better screen (transflexive). I can get it for about $30 more.
I've found a ton of info here about the 60Cx, but does anyone have any experience with the 76? Would it mount the same as the 60?
edit: and a question--I can enter lat, long coordinates in these as well right? Is it a touch screen? If not, how much of a pain is it to enter these by hand?
Super Moderator
My understanding of the two units is that functionally they are pretty much the same thing. if there are differences they are minor.
Neither has a touch screen. They are not super easy to put in coordinates although they aren't terribly hard, either, just a bit fiddly. They do hook up easily to a computer using USB and in that case it is real easy to enter in waypoints, etc.
What features do you particularly want from the 60cx? Have you considered the Zumo 450? After you're done buying the maps for your 60cx, along with a RAM mount and power cable, you're basically at the price of a Zumo 450. I think it's worth a consideration.
Did you consider the new Garmin Colorado? Pricey sucker, but pretty cool graphics and features... doesn't float though...
https://buy.garmin.com/shop/shop.do?pID=11019
$300 is about my limit. I really don't see anything all that different about the Colorado besides onboard memory, a picture viewer, and the ability to share between units. It does have a couple map preloads though...
I want it to be versatile. I want to be able find a coordinate on my fishing guide, punch it in, get as close as I can with my bike, and then hike the rest of the way.
I'll also be using it this fall to hike around and find some nice hunting spots.
Basically, I need an all-around type GPS.
Ok, then it sounds like the 60cx (or maybe 60csx?) is the best choice for you. I don't know if you'd be much happier with the 76cx, unless you plan on dropping it in the water a lot ;)
Don't forget that you still have to pick up maps for the unit, as the base maps suck.
60 versus 76
Outside of my post earlier this week about how the 60 CX is a "smokin hot unit"...........I've had a 60 Cx for 3 years - overall it's a good unit. I had some concerns, documented - regarding what I thought were flows in the case design around the junction of the bottom of the display and the case housing sides - I had minor cracks which I solved by sealing with cyroanulate glue.
The operational characteristics of the unit -menus etc are relatively inutitive to figure out but clearly not a "point and shoot interface". Versatile though and does fishing , hiking , geocaching and biking for me quite satisfactorily. . I also use (borrowed) a 76CSX. Outside of altimeter and elecronic compass feature -the units are virtually identical in operation and function. the 76 floats and is a little larger in the hand than the 60 which is advertised more for the hiking type community. Also-- the controls are on top of the screen in the 76, which means you might cover up some details momentarily when operating the controls but this is a moot point with me. On the other hand, the buttons are larger. Since I fish a lot, both wading and boating, , the 76CSX is what I'm getting as a replacement for my now defunct 60 CX. The case also appears a little more "robust" but only time will tell if that is true. In Great White north, the 76 comes with a 128mb card, the 60 only with a 64 Mb card - if that makes a difference.
One man's experience.....safe riding
Bob
