1 - 16 of 16 Posts
I got a Pelican Vault 200 handgun case that i want to mount to my OEM reAR RACK [2019 wEE] i was thinking of looping U bolts through the rack and drilling the boc and putting nuts inside. any other easier ways?
I positioned mine where I wanted it, marked it, then drilled holes in the oem rack. I used 4 SS bolts with fender washers and Nylock bolts to secure it. I highly recommend Nylocks due to the constant vibration.
this seems much easier than me trying to fit U bolts through the holes in the racks. thanks
You can consider some neoprene washers between the rack and box for waterproofing and anti-vibration.
Reactions: vboost
Would you mind posting a few pictures of that? Sounds like a perfect setup, but I can't quite envision it. Also, hello from Knoxville! :grin2:
Drilled and tapped 3 spots on my rack. Bolt/waher in and only worry about them working loose on long trips (periodic check at gas up time).
Yes I can since I am 22 days into a new knee and all I can do is stare at my bike. Stand-by for pic's..........
Ok, I lied...it was my '07 that I drilled the oem rack on, my '15 came with a aftermarket rack installed. Anyway, here are the pic's, the install on the oem is just a little more involved due to space limitations. You can however mark the box location, then take off the oem rack and drill it. It will take a little time, but way easier to access for nuts n bolts.
The box:
position relative to rear seat:
inside the box fender washers:
If you leave the rack on, drill the holes in it first. Position the box, then use a pencil up thru the holes to mark the bottom of the box for drilling. Borrow someone with tiny T-Rex hands to fish the washers & Nylocks on the bolts.
You could use time certs or such in the rack and avoid the extra nuts but whatever works is good.
I use lock washers and don't check at gas stops. I might check every other year for tightness.
For those interested the metal loops on Moto7's case they are called "footman's Loops" They are available at most decent hardware stores or Amazon for a $1 or $2 per. They are low profile and make for great places to tie off items too.
This is also a good place for a dab of purple Loctite. Or if your frugal take a bottle of the wife or GF's nail polish and put a drop on the threads. Tighten up the fastener and the nail polish once dried works like removable Loctite
Adventure Tech makes a real nice rear plate for $35.
I think he had to adjust the price quite a bit since, this was an intro offer only last time I checked. But Rick also posted some drawings and instructions for people to make their own custom versions which was very nice!
I ended up buying the PMR rack for a little over a hundred bucks including shipping which is a bit more high end with bent side rails and tapered shape.
1 - 16 of 16 Posts
