1 - 1 of 1 Posts
Some have found it necessary to remove the side panel plastic to gain access to the ABS wiring to install Eastern Beaver ABS switch kit. I was able to access the terminal with the panel just loosened in front. Releasing the 25 amp ABS fuse holder from its bracket gives the wiring enough slack to fish the terminal out and up, giving you enough room to make the connections. Then put the fuse holder back. YMMV
1 - 1 of 1 Posts
