1 - 14 of 14 Posts
I recently installed a Givi E528 rack on my DL650K6. The cover (for lack of a better term) is warped upward. It gets even worse in direct sunlight. Does anyone else have this problem? What can I do to resolve it? I know I'm being picky here, but that's why I paid a lot of money for the Givi pieces.
I think when I got mine 2yrs ago it was warped also but flattened out after a while. I don't see mine anyway because I just about never take my top box off.
Mine looked like that first time I tried putting it on. Later I realized that part of it wasn't clipped on quite right. If you take it off and look closely you should see what I mean.
Tom
Mine is like that too, and it's installed correctly. I never take the top box off though, so it doesn't matter.
I am not a *VERY* experienced rider
but as soon as I went for a ride with the top case on
I could feel a change in the way the bike handles.
It felt less stable with just my laptop in it.
Yes I was expecting that to some extent
with the wight placed so hi but it surprised me
how much it changed the stability for me.
I am wondering if I should have went with the
Givi side cases. Would that have had less of an
effect on the balance?
Instead I went with soft
luggage for the sides with the thought
that if the bike were to be dropped (heaven forbid)
on it's side that I wouldn't crack expensive Givi cases.
They don't look like they can take much of a hit and
I was/am unsure what side case could take a hit.
Maybe I just need more riding experience...
or maybe the lowering links will help.
Hi Storm Girl!
Did you raise the front forks at all (lower the front of the bike)? How are your tire pressures?
I noticed a fair amount of the bike being unstable at highway speeds (60 to 80 mph) with the E52, in particular around trucks. I raised the forks about half an inch and that made a huge difference for me.
Mind you, I'm 215 lbs and 6'2" (in the morning) so my weight/size might make it work much better for me.
V-Tom said:
Hi Storm Girl!
...Tom
I don't want to derail this thing any more than I have so
I will just say I have lowering links on order, that the front forks has
been raise, I should check the tire pressures, and my weight is
probably not helping (Im 145LBS at 5 foot 9).
You are far from having problems due to your weight, unless you mean you don't weigh enough. I'm only 150 @ 5'7" and I don't notice any issues with all three pieces of my luggage loaded. Mind you I'm using an E450 topcase and only wish I had the Maxia :oops:
Storm Girl said:
V-Tom said:
Hi Storm Girl!
...Tom
It's similar to computer hard drives: there is no capacity that sooner or later cannot be filled full. :lol:
For solo riding @ 3 days my K46 topcase and my tank bag is enough (so far).
quote]
My advice would be to give it a little more time. I don't notice any difference with my Givi E52 topcase on when it's loaded lightly (my laptop).
When I put a twelve pack of beer (or other heavy stuff) in it, I 'notice' the difference, but not enough to really be concerned about.
Think of it this way - a Givi topcase with your laptop weighs a heck of a lot less than a passenger and lots of people ride with passengers.
- Tom
Hi!
My point with the case isn't the weight of it but the size of it.
I am sure that the weight in it makes little negative difference. It is fairly large and I am sure that it makes the bike much more sensitive to winds and side gusts, expecially being a tall, reasonably light bike. My weight might help me overcome a lot of this but Storm girl is pretty light (compared to me) and might feel the effects much more so than I would.. and I was feeling the effects of gusts, turbulance off of larger vehicles, etc quite a bit.
In my case raising the forks (lowering the front of the bike) half an inch made a noticeable difference. I still feel the effects a bit, but pretty minor compared to the stock setup.
E
I just mounted my E-460 yesterday and noticed the plastic top cover is also a bit out of wack. Maybe out of wack for us Americans but over on the other side of the pond it might look fine :lol:
No biggie, just make sure the bolts are all secure all the time. Hey maybe another acronym, instead of ATGATT, its SABATT. Secure all bolts all the time..
Ok no I guess :cry:
1 - 14 of 14 Posts
