1 - 14 of 14 Posts
Yes, initially, mine did that. The metal spacer they provide in the kit is too long and it doesn't pull the two halves together enough. I just filed down both sides a very small amount and put it back in. About 3 hours of riding today and no buzz, 0-redline.
the easiest fix is to tighten the bolt connecting the bars, the one under the cooler. It does that when it's not tight enough.
Even better, remove bolt, add some rubber (i.e. from a bicycle inner tube) and re tighten.
I found that, for my install, the bolt was more than tight. But the metal cylinder spacer was too long and didn't let the gap close enough no matter how much I cranked on the bolt. Instead of over-doing it, I just solved the source of the problem.
· $tromtrooper
As a point of clarification, are talking about an audible buzz, or a vibration? My bike (maybe Givi, maybe not) has vibrations at 5-6k (peaks at 5.5k), but has never buzzed.
Discussion Starter · #8 ·
The buzz is very audible, if I reach down and grab the left side it stops. I still haven't had a chance to ride it since I shortened the spacer but I will let you all know in a day or two.
Mine has it now that I changed the deathwings to Shinko 705's. Go figure?
I'll be throwing on the Shinkos pretty soon. I doubt they will cause the Givi bars to start rattling after I fixed the problem. Right now I'm riding on a squared-off Tourance* and when I turn (onto the tire's barely used outer edge) it's like riding on knobbies - I can feel the rumble of the raised tread on the road surface.
*I ride in South Florida and have only had the bike 2 months, all tires eventually square off down here :(
1 - 14 of 14 Posts
