Does anyone know if the controller still draws power when shut off. I have Gerbing jacket and glove liners which draw about 104 watts which from what I read on the forum my 2011 should be able to handle. I don't have any other power draw GPS etc..
I wired an outlet dirrectly from the battery. I only use this outlet for two things, my heated vest and my battery charger. When I leave the bike the vest has to be off because I can't leave without unpluging it. This also gives me dirrect access to the battery for my trickle charger.I always wire stuff like that to a relay that is switched by the ignition. When the bike is off, the heat (or whatever) cannot be left running even if I forget to turn it off. On the Wee, I have a FUZEBLOCKS.COM fuse block that is switched or constant 12v for each output depending on which slot I put the fuse into. It's the bee's knees for stuff like this.
Yep, this is how I have mine wired as well.I wired an outlet dirrectly from the battery. I only use this outlet for two things, my heated vest and my battery charger. When I leave the bike the vest has to be off because I can't leave without unpluging it. This also gives me dirrect access to the battery for my trickle charger.
This is exactly what I do too. Eastern Beaver left-side powerlet outlet wired directly to the battery runs my Gerbing jacket and is also the plug for my Optimate3.I wired an outlet dirrectly from the battery. I only use this outlet for two things, my heated vest and my battery charger. When I leave the bike the vest has to be off because I can't leave without unpluging it. This also gives me dirrect access to the battery for my trickle charger.
