1 - 6 of 6 Posts
I have a gas leak in the approx 1.5 in rubber hose connecting the two carbs. The two clamps that hold the hose have been crimped on with a unique tool. Is it necessary to use a special technique or tool to remove and replace these two clamps or can I just pry them off, replace the hose and secure with normal, screw-type hose clamps?
Is this gas leaking common? Mine is an 02 DL1000 with about 12000 miles.
Thanks,
Charley
oops, "gasm leak" is a typo. of course, I mean "gas leak".
Fuel injection hose clamps?
I had about concluded that these must be special, since the gas line is under pressure. Where do I find fuel injection hose clamps? Do I need a special tool for them?
Thanks,
Charley
Pick them up at a good parts store. The only special tool you'll need is a screwdriver.
You can tell a fuel injection hose clamp from a regular one by the slots in the clamp, FI clamps won't have them.
Thanks very much. I'm on my way to the auto parts store.
btw, is the fuel line hose unique or can garden variety fuel line be used?
Charley
Hose and clamps need to be rated for fuel injected vehicles. Carbureted vehicles use a much lower pressure, a few pounds or so as opposed to 40 pounds or so with FI models.
1 - 6 of 6 Posts
