Maybe someone will benefit from this info down the road, and it will save them some time.
So let's just say for grins you are changing gas caps for whatever reason, and you're not sure whether you have a vented cap, non-vented, or what. When you get that straightened out, you're going to want to be able to keep using one key for everything.
Here's the skinny as it applies to a 2007 650. I haven't looked, but I imagine the 1k's aren't much different.
Remove the cap and ring from the tank. 4 fasteners that make a nice square are all that attach it to the tank; the other 3 are just decoration.
Turn it over on the bench, this is how both types look at first glance. I had started to loosen a few screws before I remembered I wanted to take a picture.
At about the 2 o'clock position there is a small bracket held in by 1 screw. It needs to be removed first. Be careful when removing this, it keeps tension on a very tiny spring and ball bearing that will be nearly impossible to find if you let them get away.
Next take the two screws in the middle out, and carefully remove the casting that is the tab for keeping the cap closed. There is a spring underneath this also to pay attention to.
Underneath that is a plate that simply lifts off.
At this point you get your first indication of whether you're handling a vented or non-vented cap. A vented cap has a ball bearing in the area indicated by the pencil. A non-vented cap does not have this.
I didn't get a picture of it, but at this point you can gently remove the tank seal assembly. There are yet more springs to know about underneath this, 4 of them in fact, as shown below. Set those safely aside with the ball bearing from above.
Remove the remaining 6 small screws that attach the casting to the ring, with the gasket between the two. Be very mindful of the tiny spring mentioned at the start!
Here's a shot of that spring with the casting removed. I just left this laying undisturbed for the duration.
Turn the casting over, and with a vented cap you will see this.
A non-vented cap will look like this.
It is worth noting that if you simply lift the plastic valve assembly out of the non-vented cap at this point, you have made yourself a vented cap. I rode it like this for a short while with no problems.
Now to change the tumblers. Turn the casting back over, and you'll see the o-ring in the circle. Gently remove this with an appropriately sized tool. I used a small jewelers screwdriver; a toothpick would work fine.
Under that is a ring that drops out with some light tapping on the body.
Once those are out of the way, look closely to see the retainer for the tumbler mechanism. Use a small screwdriver to push this toward the interior of the cylinder.
With some slight downward pressure on the cylinder while you're pushing the retainer, once it's clear the cylinder will slide out the other end.
Pull it all the way out, grab the tumbler you want to put back in there, or just clean this one up before reassembly. When you go to slide it back in, you'll need to press the retainer in slightly to get it started. It will simply lock into place when you push it all the way down.
As the manuals usually say, "installation is the reverse of removal." When you're replacing the main casting, be sure to pay attention and make sure the little spring is in the channel, and not pinched in any way.
Hope this proves useful to someone down the road.
Discussion Starter · #2 ·
Let's try this with updated picture locations:
Thanks! I love stuff like this. I'm making it a sticky in the "how to" section.
Seems this thread has died down for a while, but I have a question. I mistakenly got a 2015 model replacement tank for my 2016 DL650. Everything is the same except for the venting arrangement. Could someone with a 2015 share some pics of the underside of your gas cap and the open filler hole?
I need to figure out if my 2016 gas cap will work okay on this 2015 tank. The only thing missing is the second hole (located around 4 o'clock) that mates to the cap with the rubber grommet. My gas cap has the vent hole, but the tank does not, so any venting will just go out right there at the gas cap. I don't think that's a problem unless occasionally some liquid makes it through the vent (like dropping the bike off road), then there would be a little bit of gas around the cap which on my 2016 would normally go through a second drain tube out below the bike onto the ground.
Strange thing is that there are two drain tubes inside the gas tank: the normal "spill drain" and a second one that runs up to where the vent hole should be.) I took the cap apart out of curiosity and there is a ball check valve in the venting passage way to prevent any large amount of liquid coming out, but there might be a little bit in some situations.
Any pictures of a 2015 would be great. Thanks!
2007 DL650
This post was very helpful to me today. The gas cap on the used 2007 DL650 I picked up a couple of months ago was inadvertently replaced with an non-vented version by the prior owner when he replaced a worn ignition switch. It was sucking in enough air through the cap seal to run okay for short trips but I heard an odd sound after shutting down from a longer ride and could hear a vacuum when opening the fuel cap. I pulled the old cap and the replacement apart and could pretty easily tell what to do from the words. Swapping the tumblers allowed me to get the right vented cap on the bike with all the keys matching.
Discussion Starter · #6 ·
Cool, glad it was useful. Seems like I once again need to update the picture locations.
2007 DL650
A tip that may be obvious to everyone but me, take the key out before trying to remove the key cylinder.
The bike definitely happier with the vented cap. I went out for a ride this afternoon and everything works liked it should.
