Has anyone had trouble downloading mapsource new out of the box onto vista? I have installed/uninstalled and installed again, cant get through the process.
Not so far. I did in once without a problem.
Crazy Old Guy
Did you turn off your virus protection and firewall off before installing? Try going to run and typing in %temp% then OK and deleting all the temp files. You will probably see a Garmin file in there you need to get out before you install again. Good luck.
Well, it was Vista.I went to garmin and downloaded an updated version off the website. When I reinstalled everything, it works fine. Too bad the software sucks.
There is an update to Mapsource that someone posted a link to on AdvRider. Is is an update to the Mapsource program. Vista was giving me a registry error when I tried to load it. I installed the update and all is now perfect. If you haven't' done so, give it a try. It updates Mapsource to version 6.13.6.
RC
