1 - 6 of 6 Posts
Not sure where this should go but here 'tis.
I use Garmin's Map Source to lay out routes that fellow V-Strom riders use in their gpses. When telling others of a planned ride I'm usually asked "how many miles?" Can anyone here tell me how to extract mileage information from Map Source or recommend another way to obtain it?
Mileage in MapSourse
After you create your route....
Go to: (1)Edit, (2)Route Properties, then (3)Directions
You should see the Total Distance & Total Time for your route about 3/4th's down the pop-up.
Discussion Starter · #3 ·
I must be doing something wrong. After I create a route and save it, then recall the route "preferences' is grayed out in the Edit drop down
Try HD ride Planner
Effortless route editing
Look carefully dirt roads are light beige/ tilt your LCD monitor
You're correct, I've never noticed that before. Also something interesting is.... you have to click on the route name(or "select all") for the "route directions" to show up. I don't know why Garmin tries to make it so difficult?
Good luck.
1 - 6 of 6 Posts
