You need the cradle, a diamond base with 1" ball to attach to the cradle and a double socket arm of the correct length as in Mounting Adaptor Base - Composite Diamond Base with 1" Ball - RAM Mount
The double socket arm will connect the ball on Rick's mount to the ball on the diamond base that attaches to the cradle. You can see the diamond outline on the mount where the diamond ball will attach. I don't think the cradle comes with a diamond ball. If it doesn't, you'll need one separately.
The car power adapter has a 5VDC regulator built into the cigarette lighter plug. You need to step down the bike's 12VDC to 5VDC using something like that to power the unit. Probably the easiest thing would be to connect a cigarette lighter socket to the bike via the EB wiring harness. Switched keeps from running down the bike's battery if you leave the unit on the bike. Unswitched keeps the unit working at gas stops with no attention to settings but you need to take the unit off when leaving the bike. It's up to you.
