1 - 14 of 14 Posts
After returning home from a 250 mile ride, I knew it was time to start getting a little more air. I've never liked the stock windscreen and have been using the Suzuki touring screen.
I mocked-up the stock screen on the bike, then cut off as much as possible off the top. I used my Dremel tool with a cutting wheel. The plastic will melt as you cut, but it all cleans up pretty easily:
After marking up the screen in various ways trying to find a look I wanted, I settled on trimmimg the fat off the sides:
After finishing both sides, I rounded the corners a bit and cleaned up my cuts:
I then sanded the back side of the screen with a fine grit paper, cleaned with rubbing alcohol, then sprayed it with Krylon Fusion flat black paint:
It was too late when I finished to do a test ride. I'll do so tomorrow, post ride impressions, and take some better pics (it's tough to take pics of black in a garage with overhead lights.)
Discussion Starter #2
Update
So I took a test ride this morning. The screen provides clean air with absolutely no buffeting up to 70 mph (and I'm sure at higher speeds.) It is *slightly* louder than when I stood up on the pegs. I'm 5'8" tall, so it should be even quieter for those who are taller. I intentionally rode without ear plugs, so I'm sure it won't even be noticeable with them in. Obviously, air flow is greatly improved, and it should prove to be a much cooler ride this summer.:cool:
Overall I'm quite please with it. I wasn't going to use the stock screen anyway, so this provided a free alternative to commercially available sport screens.
As promised, here are some better pics:
That's COOL!!!!! I really like the looks of that.I have been thinking of doing that myself but dont want to trash the stocker cause I might use it someday.I might get some plexiglass from home depot and try that out.Paint it gloss black and put a suzuki sticker on it.I like seeing creative things like this.We ought to have a creative section in the main headings on this sight.
I see stock windscreens pop on Ebay regularly and they usually sell cheap. Or, just cut up the one you have and worry about replacing int later.:p
Sock puppet, have you ridden the bike with the shield removed ?? If you did what where the results ??
Nope, never taken the time to ride it when I had the screen off.
Looks great.....good work and very neat and tidy looking....could be a market out there?????
Thanks guys. I can't make any promises, but maybe I can find a way to trace out the screen on paper, scan it in to the computer, then post it somewhere in a printable format. Anyone know how to do this?
I did yesterday and it wasy great.No buffeting or head vibration at all.I had my visor down and when I turned my head it felt like someone was pushing on it.Lot of pressure at 70mph but a good flow of air.A better helmet would do wonders for me.Just take you shield off and try it.
I cut down the stock screen the other day, since I now have a Givi screen for when I want more protection. I used an adjustable sliding square to transfer the curve of the top of the screen down about 4", then made a rough cut with a jigsaw fitted with a plexiglass blade. I filed down the irregularities, then sanded the edge smooth. Quick tip for anyone planning to use a jigsaw: put some masking tape over the area the base plate will bear on, because even with a plastic plate cover, it will still mark the screen.
Thats exactly what I'm going to do with my stock screen for summer riding. How well does the krylon fusion stick to the screen? I am assuming you painted the inside of the shield? Looking forward to doing this project as temps are starting to climb here again!
I'll be back
Ummm I wouldn't clasify those as windshields...
Maybe bug screens?
How about fly swater?
Bee butt removal tool?
Moth masher?
+1 on the mods there boys. I did that last year too. givi in the winter. Fly screen in the summer.
Discussion Starter #14
Yep, I painted the back side of the screen. I sanded it with some very fine grit sandpaper before painting. It seems to have adhered very well, though I haven't been rough on it.
1 - 14 of 14 Posts
